Capture streaming audio to HD
Swill21
Hello all. I was wondering if anyone knows if it is possible to capture streaming audio to hard disk? I s there software to do this or will it be a matter of installing a capture card of some nature?
JustinLerner
425
It should be possible with most recent sound cards. Select Mixer input for your sound card and then use the software of choice to record the streamed audio. Unfortunately, when you capture sound in such ways, the sound that is streamed is usually sampled at lower rates, but your sound card records at higher rates. So, you get ineffecient copies of the streamed audio, but it still works.
Although I don't know of any programs which can capture streamed audio to files without re-recording the audio, it may be possible to find them somewhere.
