Get a higher amperage alternator. A capacitor will do nothing.
Mark
Wrong. All electronic devices draw more current at switch-on than they do in operation. Turning on my home theatre amp dims the lights in my apartment, but once it's on, I can turn it up as high as I like without it causing the lights to flicker.
A capacitor absolutely will help with the drop in current caused by switch-on. I doubt that he's coming close to the maximum amperage draw with the car stock. I would be shocked if the power windows were more than 10A in total for all four.
The issue is not total sustained current draw (which a new alternator would help), but rather the perfectly normal dip caused at switch-on.
Honestly, it's not an issue at all for the OP though. My 944's guages are all electric and because of their sensitivity, I can see the temp and fuel needles twitch when I use the windows or turn on the lights. The voltmeter doesn't show a sustained drop, but there's a definite drop at switch on. Car's done that for 150,000 miles and the multimeter doesn't show an amp draw even nearing the alternator's capacity.
ZV
If the car is known for having a weak alternator and he wants to correct the situation, a better alternator is needed. Or does that make too much sense for you?
Mark
If his car is stock there is ZERO need for changing the alternator. None.
Absolutely none of the symptoms he lists are related to the alternator's capacity. None.
Or is that too obvious for you?
The facts as he has outlined them point to normal operation. The fault he listed was flickering at switch-on, which would be solved by a capacitor. If he was noticing sustained voltage drop, then the symptoms would indicate that a higher capacity alternator is necessary. The symptoms, however, do not indicate a sustained voltage drop, only the normal, temporary, dip at switch-on. In this case, the heresay about the car being "known for a weak alternator" (which I've been unable to verify, the 4-cylinder has a 90 amp alternator which is pretty standard and certainly not "weak", while the V6 has a 110 amp alternator which is again pretty standard and certainly not "weak") is nothing more than a red herring that has no impact in the actual symptoms.
You're almost as knowledgeable about cars as that "Munchees" guy was.
ZV
