So I have this really annoying issue, and decided my first post ever on Anandtech will be on the subject.
I have a desktop that I built for Windows Gaming / Programming with a small hard drive inside dedicated to a Hackintosh build for audio production. (i7 870 @ 2.93, Gigabyte GA-P55-USB3, 8GB RAM, Diamond Radeon 6970, Corsair 650w PSU). I currently use a Firewire Presonus Firestudio Mobile as an sound card / audio input device, which I use both with Windows and OSX. Now here's the problem:
Something in the computer "whines" whenever I am loading something from a hard drive, opening a window with my mouse, etc. I hear it audibly directly from inside my computer, but ALSO through any 'powered' speaker, meaning any speaker / device that has its own power supply separate from the computer. (The Presonus is powered through the firewire cable). However, I do not hear the whine through my headphones. The audible noise is audible through the speakers not only through the Presonus, but also the onboard audio as well. I tested the Presonus with my speakers using my housemate's laptop and there is no noise whatsoever.
My guess is that there is a grounding issue of some kind, and when I googled my problem there seems that there are several reasons for capacitor whine, so if anyone can help me go in the right direction from here that would be great. My end goal is to remove the whine ONLY from my speakers, but if I could end the whine on the capacitor itself that would be great too. The whine from my computer is not too audible, thanks to my Fractal Design R3 case
