- Mar 17, 2005
- 10
- 0
- 0
I've been bitten by the overclocking bug, and it's bugging me that I can't overclock for beans.
I just replaced my NewCastle 3500+ with a Winchester 3500+ and the best I'm able to do is 2453.3 Mhz. This is on the very first Abit AV8 that was released (~Aug'04) -- I'm guessing rev 1.0 at best.
I'm running -19 bios.
I'm running at 4.750 volts on the cpu, 223 Mhz HHT, DDR400 memory using DDR333 timings (memory at 175.2 Mhz), and HT mulitplier at 4x. I also have my AGP/PCI locked at 66/33.
I can get it to boot at 225, but it fails superpi after about 3 minutes.
I have a swiftech water cooling setup with an external radiator. Don't ask what my temperature is, because this MB gives totally errorneous readings. I can tell you the water is barely warm to the touch leaving the cpu.
My NewCastle topped out at 216mhz.
For the life of me, I can NOT change the multiplier in bios for the cpu. It stays at 11x and it's grayed out -- can't touch it.
I've bumped my cpu voltage up to 1.55 on the cpu, and still can't get a stable 225. I'm running a PC Power and Cooling 510W Deluxe powersupply.
I'm starting to get the feeling this board is a piece of junk!
Here's the specs on my cpu:
ADA3500DIK4BI
CBBID 0505MPMW
xxxxxxxB50092
Does it make any sense that I can't get to 2600 Mhz let alone 2500 Mhz?
Thanks
Dan
ADA3500DIK4BI
CBBID 0505MPMW
xxxxxxxB50092
Thanks
Dan
