Can't narrow down the problem
Omied Sadeghi
Banned
Jul 24, 2005
80
Im posting in the general hardware section because im lost as to where this post belongs. It seems that the issue im having has so many factors that its hard to narrow down and Im not equiped to test the machine sufficiently. So here I go.
System Specs:
CPU: Pentium 4 3.0E Fan: TT Spark 7+
Motherboard: Abit IS7
Memory: OCZ Premier Series 1024MB DDR400
Video: BFG 6800 Ultra
Power Supply: EZ Media 480W
Case: Antec SuperLANBOY
HDD: Seagate 160GB
Optical Drive: MSI DVD/CDRW Combo
I was running a system test at pcpitstop.com and the results flagged my memory yellow stating it wasnt running properly. So i decided to run 8 hours worth of MemTest86...This is what I got:
Test: 5
Pass: 0
Failing Address: 0001dfc16b0 - 479.0MB
Good: efefefef
Bad: efefefed
Err Bits: 000000
Count: 63
Statistics listed on Memtest:
L1 Cache 16 11302 mb/s
L2 Cache 1024K 8169 mb/s
Memory 1024M 3012 mb/s
Do these speeds seem correct?
Test Summary
Test 0 Errors 0
Test 1 Errors 0
Test 2 Errors 4
Test 3 Errors 7
Test 4 Errors 13
Test 5 Errors 0
Test 6 Errors 39
Test 7 Errors 1
Test 8 Errors 0
Test 9 Errors 0
I then procedded to contact OCZ in the support forums to no avail. Telling me that there is a possibitly that it is my CPU or PSU.
So i purchased a diagnostic too called Hot CPU Tester 4.2.2. That just confused me even more.
:confused: :confused: :confused: :confused: :confused:
Here were my results:
Hot CPU Tester Pro 4.2.2
Copyright © 1999-2003 7Byte Computers
Sunday, July 24, 2005 - 13:46:11
Diagnostic Report
Test Started at: 07:45:33
Test Duration: 06:00:00
Physical Processors Available: 1
Logical Processors Available: 2
Multi-Processors System(SMP): Not Available
Hyper-Threading Technology: Available
CPU Name String: Intel(R) Pentium(R) 4 CPU 3.00GHz
Speed: 3006MHz
Logical Processors Tested: CPU 0
Average CPU(s) Performance: 101.1%
Modules Results:
Complex Matrix: Finished without error
Calculating Pi: Finished without error
Sorting Algorithms: Finished without error
Prime Test: Finished without error
Fast Fourier Transforms: Finished without error
Chipset: Finished without error
L1 Cache: Finished without error
L2 Cache: Finished without error
Memory: Finished without error
HD: Finished without error
MMX: Finished without error
SSE: Finished without error
SSE2: Finished without error
No errors? But didnt MemTest say I had sixty something? OK
So now Im here hoping for the answer to the question of the day. What in gods name is causing these weird errors.
Here are my PSU Specifications. Hope this helps.
Model Number: PSEZ 480
DC: 480W
AC Input: 115/230V 50/60HZ
+3.3V: 28A
+5V: 36A
+12V: 16A
-5V: 0.5A
-12: 0.8A
+5VSB: 2.0A
+3.3 & +5V Max: 265W
Let me know if ya need anything else... Hope to hear from you all soon!
Ricemarine
10,507
1. Can be your PSU possibly. since your running an ultra and stuff like that... Unless you are sure it was fine with other ram.
2.Its your ram.
