neptunefix
Hey guys (or girls), does anyone know why, with my Radeon 9200SE, I can't keep stable settings with using a dual monitor setup?
I'm running two 17" CRTs. One in the regular VGA port and the other adapted to the DVI port. I only have the option of allowing the VGA port to be the main monitor, as far as checking it off goes.
However, when I get it set up like I like it (both monitors @ 1024x768), things are fine until I rebot. WHen I reboot the main monitor reduces resolution to 800x600 and the start menu is thrown to the 2nd monitor even though it is not used as the main monitor when I open apps.
What is the deal? Possible solutions?
Thanks,
Jared
Thanks,
Jared
