Can't Install wifi adapter. HELP!
allenrosch
I have been unable to install any wireless adapter. I've tried Asus, Netgear, Belkin and at least two others. I use Win 7 Home Premium 64 on a machine that's about eight weeks old. In each case The Device Driver recognizes the adapter. It says the driver is the best driver. I live in an RV campground and depend on Tengo Wi Fi service. I connect to the internet with a Wifi Ranger Router using a LAN cable. I have made sure that Wireless LANAutoconfig service is on automatic. I'm not sure what to do about the dialogue in the Log On tab of the autoconfig box that says "allow this service to connect to the desktop". I've left it unchecked because that's the default position.
Yesterday I bought a Netgear N600 Adapter. My Network Sharing Center sees the new adapter after installing the driver, but when I right click to Enable, it runs through a little dance "enabling" but nothing changes. The system "sees" the adapter
but won't connect with it. When I try "connect to the internet" under the broadband icon, I get a box asking for user, password and domain. I have a Tengo name and password but don't know the domain. Is this the info that it wants?
Iv'e tried installing with firewalls on and off. No change.
This stuff should be plug n play, not endless grief, not plug'n pray. I'm so tired of spending hour upon hour trying to get an adapter to work. Why not just use the router, since it works? That's not the point. Sometimes the router goes down and I need the adapter
to take me to another network. I would love to have this clarified because it seems to me something didn't install correctly on my computer when it was set up. I'm missing a dll or a registry entry. There's a glitch. I have been researching the pages at EZLAN.COM but haven't found a solution.
Help, Please!
Art
That's a corporate network logon dialog box. Did you enable some service or networking driver that you shouldn't have? Like Novell or something?
After you install a standard wireless driver, you should get a little WiFi icon in the notification area of the taskbar. You click on it, select your available wireless network, put in the password if any, and off you go.
