Originally posted by: lollybo
watching anime and crap will make ZERO difference because the audio is pre-made. The sound processor on the X fi is what creates sounds with your games. Its like watching a video of Halo 3 versus running Halo 3 on your computer, you can still get amazing pre-rendered graphics, the processors on the renderer is doing the work for you. Like you said, there is a difference with gaming. I also noticed a huge performance difference with an x fi, my old soundblaster 24 bit sucked up so much CPU its not even remotely funny.
Originally posted by: bX510
When I am playing WoW, the peopel talking on ventrilo starts to static. Why is that? Settings? I couldn't figure it out. Started happening after the new sound card.
Also, my case has a jack in front for mic / headset and i have to plug the HD audio into the motherboard. Since i got a new card, i want to disable onboard sound, but the jack for the case wouldn't work. There doesn't seem to be a spot to plug in to the sound card.
I can't split the headset mic jack and hearing jack. So i plug it in the front for easy change from speakers to headset.
I got a Creative x-fi xtrememusic and hooked it up to my Creative inspire 6.1 6100.
:roll:Originally posted by: Leros
If you don't have nice speakers, then you won't hear a difference. What speakers do you have?
The static is probably digital distortion, which means too much gain somewhere. You probably have a sound level set too high somewhere, perhaps in the Ventrilo settings.
One of the advantages of X-Fi is that it can give very good analog output quality for all sources
