can't get to forums when norton fire wall is on
BriGy86
Server Error in '/' Application.
Object reference not set to an instance of an object.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[NullReferenceException: Object reference not set to an instance of an object.]
FuseTalkNet.Global.Application_EndRequest(Object sender, EventArgs e) +341
System.Web.SyncEventExecutionStep.System.Web.HttpApplication+IExecutionStep.Exe
ute() +60
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +87
Version Information: Microsoft .NET Framework Version:1.1.4322.2032; ASP.NET Version:1.1.4322.2032
i tried e mailing an admin a screen shot but it was denied
i have to turn my firewall off in order to view the forums
There has to be a way to tell it AT is OK.
Also, that is a pretty common error, are you sure it's the firewall?
yeah, i can't get to the forums when its on, so when i shut it off its fine
and norton is really screwy, it seems i have to jump through hoops to configure anything
i dond't even know where to start looking for trusted URL's
That error is on the forum side, most likely the fw is blocking part of the url or cookie that the forum code is not expecting to be missing (it should be erroring out more gracefully, Jason...). I'm running the FW here and not seeing it, try just turning off one thing at a time (like ad blocking) and see if you can narrow it down...
ok i messed with the privacy control and now let the site see my browser info, it seems to have fixed it
Originally posted by: Jason Clark
Without a way to recreate it, I can't do a thing here as the error info is non-descriptive.
It appears you weren't getting the browser info string...
