Maximilian
Hey all. I upgraded an old system of mine to a dual opteron rig and i cant get it to post, here are the specs:
2x 842 Opteron 1.6ghz
Geforce TI4400 128MB
1x 512MB PC2700 (generic stick, samsung chips, really odd shape..) ECC Registered RAM
MSI K8T FAR7
1x 80GB hdd
Antec Truepower 1.0 430W ATX PSU
It wont do a thing, i turn it on, the fans spin, the hdd light stays on and the power light remains off (probably because ive screwed up the wiring for them but they arent important atm) but it does nothing. No bios bleeps (little bios speaker is plugged into the correct place) nothing on the screen at all, no sign of life. What could be the problem?
This mobo has an 8-pin connector and a 24 pin connector for the mobo. I was under the impression that it would run with a 20 pin connector and nothing in the 8-pin, this PSU dosent have an 8 pin dual cpu connector, but i dont think its required, could i be wrong? No power to the CPU's would explain why absolutely nothing happens. But surely they can get power from the 20 pon mobo connector?
Things i tried:
Replacing bios battery
Only 1 cpu
Only 1 cpu in other socket
different vga card (this board has an AGP PRO slot, so the little plastic hook bit on the agp card actually goes into the end of the slot, it looks like its only plasti though, this isnt the problem is it?)
help!!
MSI K8T FAR7
1x 80GB hdd
Things i tried:
Only 1 cpu
help!!
