hurtstotalktoyou
Here's a goofy little problem. I have onboard graphics, and the DVI and HDMI ports work just fine on my mobo, but not the analog VGA (DE-15) port. I'm using:
AMD Ryzen 3400G
ASRock B550M-HDV
(I do not have a dedicated graphics card)
I have tried using two different displays, and two different VGA cables. Nothing seems to work. Even if I unplug the DVI and HDMI cables and do a hard reboot, I can't get any VGA output.
Any ideas what could be causing the trouble? Maybe there's some BIOS setting I need to fix?
Thanks!
AMD Ryzen 3400G
ASRock B550M-HDV
Thanks!
