Can't get my case-mounted speaker to work.
ATIFanboy
58
I changed motherboard long time ago but i think i connected case-mounted speaker bad.
There is 2 wires on speaker red and black which one is +5v red?
I did it like readme says but its still dont work. Is there way to test speaker itself somehow?
DAPUNISHER
31,728
31,658
flip the connector around. BTW, some boards default to a voice reporter/voice Genie, ect so if you have speakers connected you will hear that instead. You usually have to change the bios option to hear beeps on those boards.
ATIFanboy
58
Yep i have voice reporter, but i can hear quiet beep on boot and windows but very quietly.
You mean i should disable voice so speaker working on startup only or from windows to?
DAPUNISHER
31,728
31,658
Nah, the voice reporter is just as good or better than the beep codes so I'd leave it be. If you can hear a beep then the speaker must be working. BTW, with some boards I've used you can adjust the system speaker volume through the audio control panel.
ATIFanboy
58
Mmm i have PC Speaker there but i dont sure its it because iven if i muted it i still hear speaker when playing Doom 2 ;)
So its work, but quiet.
Btw i try to make beep from Turbo Pascal but it dont work its main reason i asking about this.
ATIFanboy
58
Eh i found it it was Sound(220) was told in manual but in real 220 is to low mor than 500 works fine lol
