can't get my 1.6A running help.............
Stallion
3,657
I have set my bios up and have my proccesor at stock 1.6 just to get it running. I then went to the start up to do my fdisk. When I get to the a prompt and type in fdisk I get an error that says "no fixed disks present"
I have checked the connections on both the HDD and mobo. I went into the bios and the drive is detected as a wd80000bb and it sees the drives ,sectors and what not. The jumper is on master and the cable is on ide1 on the board.
what could be wrong? :(
My temps are ...mb 25C/77F,...cpu 32c/89f with fans on low fans on high is MB23c/73 cpu 29c/85f are those decent numbers?
Stallion
3,657
Boy do I feel like a newb. Your the man Thugs. :) I'm not sure what I was thinking but I screwed up big time. Oh well. Everything is great now except for that it's to late to get started now.
Will hit it hard tomorrow. Thanks again.
