- Dec 15, 2006
- 666
- 0
- 76
I want to wipe and restore my Kingston SSDNow V series (425 model) to its original performance and then reinstall Windows.
I downloaded hdderase 4.0 and the earlier one. I can't get it to work no matter what I do. I've tried this Kingston SSD installed in two laptops and two desktops, all different chipsets, hardware, disk controllers, etc. I've tried it in a USB housing. I've tried everything. In fact, I've tried running this software with no SSD installed and got the same result. I've tried it under AHCI and IDE. I've tried connecting the hdd after I booted into DOS as suggested at a few places.
HDDerase always hangs, no matter what, at the screen where it should be showing what drive to select for erasing.
What the heck? I've read and read and read but I can't get it to wipe these drives clean.
Does anybody have any suggestions either for getting hdderase to work or some other method of restoring the drive's performance before I install Windows 7 64 bit on it again?
Thanks.
Thanks.
