here's the full story if you wanted to know:
3 months ago, i first set up raid and attempted to install winxp. unfortunately, at the time, asus didn't have drivers for the promise controller to support xp, but after searching these forums, i found i could get around the problem by installing the old drivers from the asus cd that was included with my motherboard. when i entered the winxp setup, i pushed f6, loaded those drivers, and proceeded to install winxp as the forums said i should. everything went fine, but due to stability problems, i ultimately switched back to win2k. when installing 2k, i used the same process without any problems.
now, after three months, the asus site has new drivers with winxp support, so i decided to try installing xp. i downloaded the drivers, entered the setup, pressed f6, loaded the drivers...but the the raided drive wasn't detected. even after i had loaded the third party raid drivers, the list of unpartitioned spaces to install windows on didn't include my raided drive. assuming asus still didn't completely have xp support, i decided on simply settled for reformatting the drive and reinstalling a clean install of win2k (i was planning on formatting anyways). unfortunately, with the new drivers, the win2k setup didn't detect the raided drive either. so i decided to go back to the old drivers i used three months ago( the ones that SHOULD work). the setup didn't detect the raided drive AGAIN! now i'm in a pickle.
why, after doing EXACTLY what i did three months ago, am i not able to format my raided drive witht he OLD drivers that worked just fine before? is there something i need to set in my motherboard's bios? if so, what? do i need to delete and recreate my current array? thanks to anyone who can help me.
