Can't find patch panel in pre-wired home
Glacion1313
4
I'm about to move into a (rented) new house this weekend, which is pre-wired for LAN. The landlord, predictably, is clueless about the specifics of how the house is wired, and has no documentation of any kind. So, I am left to try to deduce the network topology based on observation. Here is what I know:
1) Most rooms have RJ-45 jacks in the wall.
2) There is a panel in one of the closets that has a bunch of Cat 3 and Cat 5e cable running into it. HOWEVER, there are no RJ-45 plugs or jacks in that panel.
In previous places I've lived, the central patch panel has some place where I can plug in my router and cable modem, but that doesn't seem to be the case here. I have generated a few theories:
1) The network is some sort of bus or tree topology that doesn't have a central hub. Every port in the house is physically connected to every other port.
2) The electrician just didn't bother to attach RJ-45 jacks to the ends of the cables that are in the patch panel. I don't remember whether I saw un-terminated cables in there.
3) There is another central patch panel somewhere in the house that I somehow have not found.
Does anyone have any experience with this kind of situation? Or any advice on how I could gather more clues as to what is going on?
Thanks,
Ed
bruceb
8,874
111
Most likely what you have found is the proper place and the electrician (thankfully) did not
install the RJ45 plugs .. He most likely would not have done a good job as that is a bit
tedious and requires some level of expertise. I suggest you remove one of the RJ45 wall
plates and see if that end is punched down. If it is then you can use a toner to plug into the
RJ45 jack and an inductive probe (comes with the toner) to find which cable is which at the
other end. You can also buy a RJ45 Tester which will check for miswiring end to end and
will also do a basic test of the cable quality. You will need to get a Patch Panel to install at
the closet where all the cables are and also install the ends yourself.
Suggestion: If you do not already own an RJ45 Crimper, buy one that is a Full Cycle Ratchet Type.
That way, you are sure of making a complete crimp. Also know that there are plugs designed for
Solid and other for Stranded Wires ... your inwall cable should be Solid conductors.
