Can't find a decent sound card...
Astray
131
Our company needs to find a sound card that has two input areas, one for a hauppage wintv-go and another for a XM Radio, we could use a splitter, but we would rather not.
Any ideas where we can find such a card? I've tried creative with no luck.
oynaz
2,449
You will need a sound card designed for musicians for that. M-Audio has some decent cheap ones, but there are many others. Check a music store for other options.
Auric
9,591
Creative consumer cards have several inputs -usually one RCA mini jack on the backplate and the others on-board jacks. Then there is also the ad_ext pins for after-market or DIY connections. So, at worst it is just a matter of a cable adapter for the output from one device.
