OK, ive been going around trying all sorts of stuff to fix this problem. just built the rig, has never turned on. I replaced the mobo, power supply, etc. I tried the card in a different computer and works fine. i get absolutely no signal to the monitor. doesnt make any sense.. what could the problem be assuming the mobo works? if the memory was bad, I would at least get a warning notice on the screen right? only other thing i can think of is a bad CPU. I unplugged everything except the ATI card, keyboard, mouse, monitor. removed HDs, other cards, drives etc. still no go. my 12V rating is 18A and 16A (dual source). Switched to Antec Phantom because it had the right connectors (24 pin, plus 6 pin molex for ATI card).
How can I figure out what the problem is?
