Can't connect pc to tv using dvi-d
dbk
17,685
10
I bought dual link dvi-d cables and tried to connect my pc to the tv but it doesn't work.
I keep getting this "PC / DVI" popup that bounces around on the screen for a minute or two - then the TV goes into standby mode.
It worked fine using a VGA cable and a DVI adapter but I can't use a straight dvi cable.
When I had the VGA cable - the TV was set at DVI - Analog.
Obviously with the DVI cable it would be DVI-Digital. I tried to change TV to that setting and swap the cables but it still didn't work.
I think the TV is detecting the signal through the cable because if I take out the cable the TV gives me the "Check Signal" message.
The dvi ports on pc and tv are DVI-I but shouldn't both be compatible with DVI-D connection?
My VGA to DVI adapter is DVI-I.
Help
dbk
17,685
10
Originally posted by: PurdueRy
What is the output format of the computer to your TV?
video card has dvi and vga ports
right now - vga to vga+dvi adapter (tv)
I want to go from dvi (video card) to dvi (tv) using a duallink dvi-d cable.
PurdueRy
13,837
4
By output format I mean resolution and frequency
dbk
17,685
10
1280x768 @ 60hz same as tv native
PurdueRy
13,837
4
1280x720 @ 60hz same as tv
You need 1280 x 768. See if you can change that in the video output settings or through a third party program like powerstrip.
EDIT: I see you edited it
Does it work at 1024 x 768?
dbk
17,685
10
Still doesn't work at 1024 x 768
same thing happens - "PC / DVI" popup message then standby mode
