OK. It works fine when I use the USB cable that came with the modem, but when I try to use the CAT5 cable, and connect the modem to the LAN ports on the motherboard, it won't work.
Usually I'd say drivers aren't installed, but they are. They must be.
It's a DFI nF4 LanParty Ultra-D, with dual LAN (Nforce ethernet, and Marvell LAN).
I've just installed the drivers, and it still won't connect to the net.
Help.
Help.
