I have trouble changing the multiplier in BIOS....i dont really know what i must enabling to have control over the miltiplier. Do i need to update bios maybe. I have an ASUS mobo P3B-f with the original BIOS...i havent update them yet.
Secondly in bios i can only set the voltage and FSB/PCI speed at preset values. For example i cant go lower the 2.00volts, i can only go up to (i think 4, not sure) and i cant specify the FSB speed.... for example i cant have 117, but i can have 110, 112, 120...why is that. Can i set also the FSB seperately without changing the PCI speed? Can i have FSB 120 and PCI 33mhz, insted what they give me 120/35?
Last question is that when i used the setting that they gave me (120/35) and rebooted i didnt even heard a beep and nothing was working, i couldnt even turn the comp off! so i had to switch the master switch to turn off all of it (speakers, monitor etc.)
Could that be because the PC100 RAM i had couldnt run at 120mhz? OR was it because the voltage was too low and the processor didnt get enough juice to think?
PLZ Advice........Thank you!
