This is really starting to confuse me...
Here is some background to preface this problem.
Duron 700 with Coolermaster Heatsink/Fan
Asus A7V Rev. 1.02
384 MB PC-133 SDRAM (Micron)
300 Watt MPT-301 ATX Power Supply
GeForce 2 MX w/ 32 MB SDRAM (Guillemot Hercules)
Western Digital Caviar 19 Gig HDD IDE
Pioneer 515 IDE DVD-ROM drive
Phillips 4x2x20 IDE cdr/w
SP (Super Power) Mid-tower case
Generic Case fan
I just bought the components and put a system together myself (possible mistake).
It worked great for a few weeks. I then put the DVD-ROM drive noted above
in and now the damn thing won't power up. The mobo power-on indicator LED comess on, but
the fans on the power supply, CPU, and on the case do not power up when I plug
the power supply in. They just twitch a little and then stop. I can't turn on the computer
for any reason. Weird. I tried disconnecting components one by one starting with the DVD-ROM drive. No go. I'm worried I might have fried something with that damn flaky dvd-rom drive.
But here's the strange thing. SOMETIMES, when I put the computer on it's side with the side case cover off, and plug it in, the fans come on for a bit, stop, and then I CAN power it on. It loads up and boots up Windows 2k perfectly. I then tried to turn it upright and put the case on for airflow... AAARRGHGHHHH! The thing completely shuts off.
I unplug the power supply plug and then replug... no go. The same "fan twitch" as before.
Now turning it on its side doesn't even work. I just recently replaced the old power supply with the MPT-301 noted above, thinking that was the problem. Nope, neither Power supply works.
Sorry the post is soooo long, but I wanted to be as thorough as possible.
PLEASE HELP ME! Thanks in advance.
wh00kah
Asus A7V Rev. 1.02
Generic Case fan
wh00kah
