Rob_63
I am unable to access the bios using the DVI connector with my Dell 2005 FPW. When I cold boot or reboot I get a "cannot display this mode" message, then it works fine when it goes into windows.
I can however access the bios with the sub- D connector.
I tested the "self test" feature according to the Dell troubleshooting manual and it tests OK.
I am using a BBATI X800XT vid card that has both sub- D and DVI out, however only one will work when both cables are hooked up unlike the 2001FP that I used to have. I use the sub D on a folding box so using it full time on my main rig is really not an option.
Any ideas?
EDIT: this is the second monitor, the first one was returned due to 11 stuck pixels, that one was dated 4/2005 and it didn't have this problem. this one is dated 11/2004
Any ideas?
