Canned Air replacement made with CO2 Paintball air tanks?
Status
Not open for further replies.
Thetech
571
I've had no luck getting a good answer, I'm looking for an alternative to cans of compressed air for cleaning computer and electronics. I'm trying to find something small and portable so I don't have to lug some huge air compressor around.
I also realize that whatever is used can't contain oil, or cause a static charge like a vacuum. One of my gripes with canned air is as the can is used it freezes up and it won't blow at full pressure until it warms up again. So therefore I have to use multiple cans of the stuff in rotation. Not to mention the wast and expense.
I have heard of people using paintball air tanks with attachments as a replacement for canned air. But no ones every explained how this works or what they have used exactly to do so. I don't know jack squat about paintball equipment.
And that's why I'm asking here! Everyone here seems to have their hands in everything, so I figured this was the best place to ask.
krylon
3,927
4
That's what she said
DarrelSPowers
781
Uhhh, heres what you do with the paintball gun.
1) Remove the hopper, make sure there's no paint in the chamber.
2) Screw in the air tank, turn safety off.
3) Go to town shooting air at whatever... your keyboard, cat, small children, whatever.
Now was that so hard?
mugs
48,920
46
I think he's looking for a better solution than that.
Thetech
571
Thank you for the 3 step tutorial, but I'm trying to use the equipment if possible for CLEANING electronics.
If I wanted to play paintball I could easily find the information for doing so.
Thetech
571
Alright awesome, Thanks Ns1 and captains, do any of the tanks contain any oil or additives? That could possibly spray onto components I'm cleaning? *Ouch* Is the air that comes out moist or cold/hot?
JDub02
6,209
the air is always going to be cold. you're decompressing it .. just physics. they get hot when you fill them back up.
dougp
7,909
4
You do realize that the CO2 is probably going to be liquid coming out at that speed? You're better off with an on/off ASA and a nitro tank, but still high pressure.
Ns1
55,420
1,599
I've never had a problem with a CO2 tank + ASA
Status
