canadian guy needs mobo ram help
parasitegoth
Ok i've grown up on computers but im a lazy person. i built my computer in november and i let it detect default bios my mobo is a crappy msi kt333 ultra2 due to the lack of the cnd dollar. ok here are the specs powmax 300w im also running 2 types of ram pc266 128ddr pc333 256ddr athlon 900 aopen 50x aopen justlink 20x/10/40 and a quantum fb 20gb aslo gf2ti 64ddr now im wondering what should i set the the voltage to and im not too familar with the type of pin my ram is i havent checked just curious how to set it up with the ram to run good
thorin
If the system is running stable and you aren't OC'ing it don't change anything, the only reason to change voltage(s) is if you're running something outside spec. You could perhaps adjust your RAM timings for a slight (1 or 2 FPS) performance increase but without knowing exactly what RAM it is all we can do is tell you to experiment and see what works.
Thorin
