- Oct 25, 2004
- 1,366
- 0
- 0
I'm trying to think of ways to bring the cost of water cooling down. A fish tank pump could work? maybe? I'm not really sure if that would even be cheaper.
Originally posted by: NokiaDude
Well, no. Because fish tank pumps are designed differently than true "water pumps". And I doubt it'd be cheaper. Just buy a true water pump you noob.
Originally posted by: AnnihilatorX
I ever wondered if algae would grow in the warm CPU heatsink blocking the water flow eventually
Yup, it will. if you aren't very careful about your coolant mixture.
Water cooling sounds like too much trouble to maintain just for a few degrees... mixtures.....cleaning the water.....tubes.......leaks......the word 'careful'......am i right??
Originally posted by: GuitarDaddy
Fish tank pumps pump AIR
Water pumps pump WATER
Originally posted by: Greenman
I need to add the same thing I put in every water cooling thread: Air is getting really good, so good that it's hard to recomend water. Before you dive in (pun intended) give the new heat sinks a good look.
Air has been really good GM, but I wouldn't say it's getting better. It's still variations on a theme, and that theme is moving hot air around in your case instead of exhausting it efficiently. Also, and I don't mean this in a negative way, if you think air is fine why evangelize against water in "every water cooling thread?" Live and let live.
Yeah thats true.
I'm not against water cooling at all, I use it. I just think that the best air coolers are pretty good, and worth looking at before someone spends a couple hundred on a water setup. A lot of the threads about water are from people who have stock cooling, and think water is the next step.
Perhaps I need to word my advice a little better, my intent is to inform the poster that there are other ways of cooling that might work for them, and they should look at all the options before making the leap.
Better?
True, to some degree. If your case has no lighting in it whatsoever, than algae shouldn't be a problem even with staight water with nothing added. That's why most water pipes are opaque, so light can't pass through them. Algae needs light to grow, without it, no algae. Additives are usually incorporated for their corrosion protection, not nessecarily to prevent algae.
