Can you recommend a Bittorrent client?
Snowcatrm
60
I have utorrent. I have a problem though. When I click on a torrent to download, all I get is Find and Save options. How do I get the option to open it? I want it to just open up utorrent and start downloading the data.
dealmaster00
1,620
uTorrent. It's not open source but who cares??? 5-10MB memory footprint on average (if memory serves. Might be less).
hans030390
7,326
I used to use uTorrent, but there were some large downloads I would ALWAYS get corruptions with.
Example: An iso was split up into multiple RAR files, and everytime I tried downloading it (at least 3 times), one of the files would be corrupted.
Actually, I think Azureus did that as well.
BitComet has never done that and works flawlessly.
But other than that, uTorrent was the best for me. I should probably try to switch back.
n7
21,281
4
I was a hardcore Azureus user for a long time.
Then i discovered uTorrent.
dealmaster00
1,620
That's strange...downloads split into multiple RAR files work perfectly fine for me when I use utorrent. It's probably not utorrent but a different issue...
n7
21,281
4
It's certainly not uTorrent.
Corrupt downloads can occur with any client, & considering how many things i've downloaded over the years w/ uTorrent, i'd say the issue is your source or perhaps bad RAM or something killing them.
RESmonkey
4,818
I need to switch. Azureus crashes my PC due to some USB cable modem driver BSOD...although, it's the program of choice.
gizbug
2,621
Save us time and use the SEARCH FUNCTION found top of the forum.
utorrent since you're lazy.
