Can you guys help me with a cable modem problem?
rambow
Banned
Dec 6, 2005
188
The "Arris" (arris is the brand) modem that comcast gave me is usb and ethernet compatible, however, only the usb works.
When I connect to my computer via ethernet, the 'getting IP address' message comes up then goes away saying that it was unplugged. I'm sure its not a problem with the hardware on my end, and that it is infact a problem I need to solve with the modem.
Any suggestions?
Connecting via usb works without problems, but I kinda need ethernet for my network, since the bridge I currently have set up is annoying. Comcast says that since my modem is up and running and the network I have works, they don't think I should get a replacement.
Cliffs:
1. Connect Comp/Modem via ethernet
2. Get errors that would imply that im constantly plugging in and unplugging ethernet cable
3. USB works fine
4. Needs ethernet for $$$profit
ojai00
3,291
I would check to see if the cable that's connecting to the model is a crossover cable. That can cause occasional problems. Otherwise, I would get another modem.
