Can you guys help me with a cable modem problem?
rambow
Banned
Dec 6, 2005
188
The "Arris" (arris is the brand) modem that comcast gave me is usb and ethernet compatible, however, only the usb works.
When I connect to my computer via ethernet, the 'getting IP address' message comes up then goes away saying that it was unplugged. I'm sure its not a problem with the hardware on my end, and that it is infact a problem I need to solve with the modem.
Any suggestions?
Connecting via usb works without problems, but I kinda need ethernet for my network, since the bridge I currently have set up is annoying. Comcast says that since my modem is up and running and the network I have works, they don't think I should get a replacement.
Cliffs:
1. Connect Comp/Modem via ethernet
2. Get errors that would imply that im constantly plugging in and unplugging ethernet cable
3. USB works fine
4. Needs ethernet for $$$profit
mrSHEiK124
11,488
Solution:
Go buy a Motorola SURFboard
EDIT: Let me be the first to say, WRONG FORUM! *points to Networking on column at far left*
rambow
Banned
Dec 6, 2005
188
Originally posted by: mrSHEiK124
Solution:
Had one, replaced when we got Broadband phone.
Does motorola even make a phone/internet modem?
Edit: i knew i did something wrong.
mrSHEiK124
11,488
Solution:
You could get a phone/internet router and hook it up to a normal modem. Makes more sense, you can use a good modem like the SURFboard, and AFAIK, Linksys makes a router that's pretty much a WRT54G with the hardware needed for VoIP and two RJ-11 jacks.
