I'd do an Eclipse HU. The new years models are looking stellar. Excellent prices and feature packed out the wazoo.
Anyways...
Eclipse HU - around 400 (havent researched the low-mid lines enough to know what you need. i can if you want)
Do you HAVE to have 6.5's? And 4?? I'd do 1 good component set and the subs. I dont like rear fill though (I HATE rear fill)
So, components.....
CDT Audio
Koda Components from Adire
Those are actually the two brands I'm deciding between. CDT's are a bit more, but every review I've heard of the Kodas has put them right on par with components costing MUCH more. And, I already run some Adire subs and absolutely love them (It actually).
Crystal, Focal and Seas Lotus are also options. MB Quart as well, but for some reason i dont care for the sound of them as much. Infinity is (IMO) a good, run of the mill brand. Its what you get to sound good but it seems pretty neutral to me (Which is good in soem cases)
Subs....
Heres where it becomes a bit more difficult due to space required. Some subs LOVE space. 5 cubic feet a woofer isnt unheard of. I assume you dont have that much to give, so lets stay on the smaller side.
Brahma by Adire
Shiva by Adire
Elemental Designs Audio
Resonant Engineering
I use a Brahma 12 in 1.5 cubic feet selaed with 1500 watts. Its amazing. Excellent sound quality and Christ it gets loud for 1 sub. They require a fair amount of power to really stand up and shine, but take very small boxes as well. Shiva is just a budget sub for Adire, but alot of people run them with very good success. I believe they like bigger boxes though, which may be a problem.
Elemental Audio, I'd LOVE to get some of their subs. ALOT of happy users. I'd also recommend them in a heart beat.
Resonant Engineering I believe uses the same motor as the Brahma with a few minor tweaks. I've heard the RE's are a bit louder, the Brahma's a bit better sounding. No firts hand experience with the Re's though.
All would be good, giving you great SQ with good amounts of boom.
Most of that isnt your common JL Audio Orion kinda stuff. Its very good, not well known. Especially the Shiva. No cone markings, it looks like swpa meet crap. Till ya play it
😀 As I said, I'm not a fan of rear fill, so I just recommended some components. Perhaps go with a 3 way set instead of 2 way and throw the midbass in the rear deck, but I just hate mid/highs on the rear deck.
Anyways, Eclipse HU, Koda components and 1 12" Brahma sub is what I would do. Add amps as needed.
Eclipse - 400-ish
Kodas - 370
12" Brahma - 400
1170. No amps or install. You could get by the components on the HU, or get some JBl amps. JBL is the bang for the buck amp to buy IMO.
