<< Get a digital to analog converter >>
Why would I do that when I can just use my Santa Cruz?
<< in other words, you need a reciever that can decode dolby digital, or a speaker set with a dolby digital decoder.. >>
Indeed. The nForce can ENCODE dolby digital...but not DECODE it...
I don't have a reciever, nor do I want to try and fit on in my room, and most speakers that do it are over priced for the sound quality when I could juse use WinDVD and my Santa Cruz in 4 speaker mode.
<< Hmm, never thought about that... So were all the tests where it has very low CPU utilization run with only 2 speakers? >>
Guess so...
In another thread I asked:
So basically unless you have an external decoder this is a 2 channel sound card?
The repsone I got was:
<< Yup. I've been fruitlessly bringing that point up for a while in several nForce vs. mobo/video/Audigy combo discussions. From the looks of the nVidia reference solution, you have to use a ACR/AMR/CNR slot or add two additional codecs on the mobo since the codecs apparently aren't integrated into the MCP. None of the boards is implementing the 6-channel analog outputs so far, so if you want 5.1 sound you either have to have or spend some more dough on speakers with digital inputs or a receiver with digital in. Doesn't look like there's any 4- or 5.1 channel virtualization yet either. Of course every time I've repeatedly mentioned this I get blissfully ignored by the nForce fanboys.
This is a general problem - I don't care how great nForce is, the mobo manufacturers so far have implemented it rather poorly. I won't even start with the Asus A7N266. Or the lack of decent 220D boards. >>
Not sure what to think about that.
Apperntly the onboard audio isn't as great as I've been led to believe...the onboard video certainly won't offer anything over my Radeon 7500, and the onboard NIC...mmmkay well that may be handy, but I do have one already, and they are only like $30 instead of $150...
Why would I want to exchange my AMD761 board for this again?
ohhhh right...7 or 8 % performance improvement...why wouldn't I just use that money to buy a faster Athlon?
Guess the nForce doesn't really interest me after all...
