Can you damage a Sandy Bridge by overclocking?
YES -- you want to disable thermal throttling while over-clocking. Then, you have a choice. "Will I allow the processor to exceed the default TDP (72.5C)?" Or -- "Will I re-enable throttling at the TDP in BIOS after OC'ing to a point where I know the processor will not quite reach that temperature at normal room ambients under MOST circumstances?"
72.5C sounds closely related to Tcase. Did you pick that?
Lets get it clear. Sandy will throttle at 100C, Ivy at 105C because thats their Tjmax.
Tcase is located on top of the IHS. And the only way to measure Tcase is to to manually place a sensor there. Basicly there is noone on this forum that got the Tcase value of their system.
Tjunction/Tjmax is measured inside the die.
Disabling thermal throttle is the dumbest thing you can possible do. It wont make you overclock better at all. It will just give you a much higher risk.
OMG, why argue this, just turn off thermal throttle and GO TO THE MAX 😉
Disabling thermal throttle wont make you OC more. Nor will disabling EIST/C1E etc.
Only thing you disable thermal throttle for is LN2 etc. Since the Tj can pass its negative values and return to a higher number. Hence thermal throttle even tho its -150C.
You really need to stop trying to be funny because there are people who might actually take your advice.
It's not really funny.
I didn't "pick" anything -- 72.5C is just the Intel spec temperature for the BIOS setting that causes the processor to throttle back a bit (even for a single core) when that temperature is reached. We're talking about two different "throttling" items here.
Correct me if I'm wrong, but the TjMax spec is the temperature at which the processor simply shuts down. And -- you can run your processor as close as you want to that spec. Nobody is going to stop you. Like I said -- "Hang your A-- over the edge of that there envelope if you're not afraid of screwing the pooch." [I loved that film . . . ] But the 72.5C spec is on the Intel web-site for the SB processor. It's implemented in a BIOS "thermal control" feature which can be turned on or off.
This spec I mentioned uses as a reference the TCASE value -- about which you are posi-lutely abso-tively correct. Top-dead-center on the integrated heat spreader. The only way to "measure" it is to estimate it using the Tj core temperatures. OR-- grind a divet in the IHS or heat-sink base and install a thermal sensor of your own. So it's an extrapolation based on the Tj sensors, thermal properties of copper, etc. If a monitoring software attempts to "show" it, they simply implemented an algorithm using the only sensors available.
But it is still the reference value for the throttling temperature I mentioned.
You can even watch this during a stress test. Turn on the motherboard thermal control feature, boot up, run IBT or Prime95 with a temperature monitoring program and a CPU "usage" monitor or the Task Manager. You'll see one of the cores begin to throttle back if your Tj sensors show a value somewhere over 80C. Generally, given the thermal properties of nickel-plated copper heat-spreader, the Tj temperatures are supposed to be about 10C higher than the . . . elusive, extrapolated TCASE.
And I don't know why Intel continues to use it as a reference -- they just "do" . . . .
That's far from enough then. People aught to live by my advice. Learn from it buddy. 😎
Cuz thermal throttle is for pussies.
Hey man, I don't deny the technical issue.
The debate is about giving your computer BadAss + 10. which is only achievable through Thermal Throttle : DISABLE 😉
I am fully aware how it all functions. There is no such thing as you claim. I havent seen or heard your 72.5C claim either in any BIOS.
The CPU wont shut down at Tjmax. It will start to throttle at Tjmax. But still function and keep working. And Tjmax for SB is 100C. Tjmax for IB is 105C. Its listed in the datasheets.
Tcase and Tjunction aint related as you think. They aint related at all.
attachment.php
I can slow the fan on my stock cooler while running Linpack. And I can show you my IB running at 3.6Ghz turboed at 104C without throttle.
Alot of people simply took the Tcase values and ran with them. They had no idea what it was. But they used it as reference. The only people using Tcase values are OEMs.
The Tjunction sensors are calicrated and shows the correct value. Not 10C higher than actual or any other nonsense.
+1 for that . . .
You can turn the Thermal Control feature off -- as you say -- even if you do "pussy-over-clocking" for which I might be accused.
Point being: even the mobo makers make mistakes in their BIOS revisions. I think ASUS, for instance, had it wrong with last year's Z68 boards, so the thermal control "throttling" kicked in when a Tj sensor edged over 72.5C. A later BIOS revision "corrected" that -- if you can call a corrected extrapolation a "correction."
But when over-clocking, I'd think you'd want to turn off that thermal control feature. If the processor kicks back a little -- even on one core -- while doing a stress-test, then it's an invalid stress-test. It might not BSOD or throw up a thread-"stop" when it should -- given your provisional, test speed and voltage settings.
After that -- I don't see any prevailing argument one way or the other for turning the BIOS feature on or off, unless your stable over-clock is going to exceed that temperature value [or maybe a Tj temperature average in the mid '80s Centigrade]. If it's a stable over-clock that's just several degrees over the Intel 72.5C spec, you'd want to turn it off -- "DISABLED." If -- as do I -- you want your stable over-clock to stop short of the 72.5C spec, then you CAN CHOOSE to turn it on after the "stress-test shakedown cruise," and only for a margin of safety -- as when you are spending the summer in Baghdad and there's a heat-wave with no air-conditioning. . . .
+1 for that . . .
No, not even in Baghdad.
CPU location, Baghdad + Terrorist: BadAss + 20 😎
It was meant to be!
It was meant to be!
Which may also be true -- sans laptop wielding terrorists.
Point is -- it wouldn't make a difference either way with my overclock settings, but I'd DISABLE it if there were any chance at all of it kicking in for a higher speed and voltage setting.
If you "feel the need for speed" and you have a stable setup, you don't want the thermal control to kick in just for a few degrees -- or even ten degrees C higher. . . .
attachment.php
Sorry, but I read too many articles on this -- here at Anandtech (not the forums) and elsewhere. TCASE was always in a range 10C lower +/- from the Tj temperatures. Look at the Sandy Bridge spec sheet or earlier processors on the Intel web-site. It's all explained in the chapter on "thermal environment" and thermal control.
The Tj sensors are under the processor cap. They ARE the sensors. Even so, they vary in accuracy a few degrees either way. TCASE is a standard measured at center of the processor cap. If there ever had been a "TCASE" sensor before, there isn't one for the last several generations of CPUs. And the TCASE value -- measured, extrapolated and anything else -- has always been less than the sensor values.
You can believe, disavow -- anything you want. I just know what I know. And the sad part of it: I just visited the Intel web-site to look for information in the format that was always available there -- spec manuals for each and every processor, organized in chapters. They don't seem to offer that material anymore. But you CAN find the TCASE spec for the 2600K processor, and it is 72.6C.
+1 for that . . .
No because when overclocking you should NEVER reach 105c ever. Not even remotely close. There is no throttle @ 72.5c thingamabob. Never was, never will be. Stock cooling doesn't keep it under that sometimes.
I have all thermal controls on and I'll tell you this. I get up to 80c on my CPU and it doesn't throttle. It keeps chugging away maxed out.
It won't throttle at all until 105c.
The tcase is given for each cpu on the Intel website, the tcase for the i5 2400 is 72.6C, the i3 2100 probably has the lowest tcase at 69.1C. Given the location of the would be tcase sensor, tcase is always lower than tjmax (sounds like the discount store).
Tcase information is useless for regular people. Hence also why there is nowhere you can measure Tcase on your mobo/CPU. Tcase is used by OEMs. And there have never been a Tcase sensor in any Intel CPU or motherboard.
I tried to explain it to you. Even showed it. You just didnt understand what you read it seems.
Tjunction is the only temperature you got. And there is no way to extrapolate it to Tcase.
Try lookup how you measure Tcase on intels site. Then you will see how wrong you are. And then see what Tcase is used for next.
You would also note that Intel only specifies Tjunction for mobiles. For example 105C here:
http://ark.intel.com/products/64887...ssor-Extreme-Edition-(8M-Cache-up-to-3_80-GHz)
Simply because mobile chips dont have an IHS. In other words, mobiles dont have a Tcase. And yet you claim Tcase is whats measured.
YES. TCASE lower than TJMax -- by a pile.
FIRST -- let me apologize for this, because I almost spawned a falsehood. SHINTAIDK is correct about some of this.
I went back to search for articles I'd read between 2004 and 2006 [which I should have printed to PDF and saved in an archive. . . But I didn't.]
TCASE "Max"(?) is a temperature spec BELOW which the processor would never throttle.
According to some information I dredged up (all in the last hour or so), a TCASE value in excess of the processor spec (on the Intel processor spec-sheet) defines a range up to TJMax considered to be an "overheating condition."
The TJMax value will indeed cause "throttling down," but the total shutdown of the processor is not far above the throttling threshold.
It irks me that Tom's Guide, Anandtech and other sites aren't keeping a total library of their published articles. In my searches, I find a lot of forum posts -- with some "experts" answering. But even so -- these knowledgable gurus also can be wrong and make mistakes.
Here's a thread at Tom's forums, with some insight by a contributor named "Computronix:"
http://www.tomshardware.com/forum/254214-29-tjunction-x6800
Note particularly his paragraph here:
[BEGINNING OF QUOTED EXCERPT]
Don't feel like you're alone; many others are also confused by Intel's thermal specifications. To answer your questions, technically speaking, no and yes. Intel's papers go to great lengths explaining how they test CPU temperature in the lab to measure Tcase Max, which if you might have noticed, is defined to the tenths of a degree, while Tjunction Max is just a round figure such as 85c or 100c.
To put it into simplified "real world" terms, the practical difference is that Tcase Max applies to operating temperature, while Tjunction Max applies to shutdown temperature, which is strictly for overtemp protection, so you don't toast your transistors.
As soon as you exceed Tcase Max, you've reached an overtemp condition, in which you can still push the temperatures even hotter, until the processor throttles, and then finally shuts down at Tjunction Max.
Think of it like the temperature guage in a car, except the guage has three needles; one CPU needle which is alwyas 5c lower than the two Core needles. We all know the red zone, which begins at 60c-65c-65c means hot, but if you keep driving until the needles are pegged at 80c-85c-85c, then it's going to shut down.
[END OF THE QUOTED POST]
And again -- my apologies, but I thought I noticed throttling during last year's over-clock project based on TM1 [and/or] TM2 "ENABLED" on my system -- coinciding with temperatures in the mid-80's centigrade. When I disabled the settings, the throttling at the same OC settings did not occur -- was not apparent in the monitoring software. Further, I think I know the difference between "real" throttling back of a processor core and the unloading of the processor that occurs between iterations of either IBT or Prime95.
But the key point here -- and as discussed on the 2009 thread to which I posted a link (above) -- this has always been confusing to people. The forum thread notes that Intel has never been entirely clear or helpful about these standards, and many people find themselves confused about them. Here for instance is an actual published article, attempting to explain the specs, temperatures, standards and "maximums:
http://www.techreaction.net/2009/10/14/guide-to-understanding-intel-temperatures/
Now there had been some other insights of colleagues here posted last year, to the issue that similar conditions that you might think are "throttling back" occur just for voltage settings that are a hair insufficient.
For myself, I simply chose as my limit an approximate average of Tj sensor temperatures at the TCASE 72.6C value. This, of course, meant that I might have reached a stable OC of 4.8 Ghz (or thereabouts) with higher temperatures. But I simply chose to stop at that 72.6 value. Which also means that the actual TCASE temperature for those overclocks was 5 to 10C below the peak temperature.
Just a footnote about my Sandy Bridge OC'ing -- or for that matter -- any OC'ing. Voltage is always a more substantial threat to processor life than temperature. Point being -- given my arbitrary ("pussy") choice to keep Tj sensor temperatures below ~75C, everybody here knows that as voltage goes up, temperature goes up. And I had chosen to limit my load voltage to approximately 1.35V. [In fact, the unloaded voltage while the processor is still at "turbo" speed is higher than that. And, also in fact, my unloaded voltage would actually reach around 1.37V]
If I wanted to volt the processor higher, we would all agree that there was plenty of "wiggle room" on the temperature. But I DIDN'T want the core voltage to exceed the levels I mentioned. It wasn't the temperature that stymied me: It was my self-limiting voltage choices.
Best computer I've ever had, though. Hasn't crashed or malfunctioned in any way since before I finished the stress-testing last year.
The other thing is, just because Prime spikes the CPU to 80c doesn't really mean anything for real world usage. I get 85 or 86c in IBT, around 80c max in prime but in games nothing close. Even Battlefield 3 only barely gets to 75c.
So I do suggest for those concerned with temps to do things outside of stress test. Encode a video, play a game for a while etc. You should then see real world numbers.
In terms of voltage vs heat vs Mhz. With Ivy it seems that the hotter your CPU runs the less overclock room you have. For example, people on LN2 have overclocked to 5Ghz on lower voltage than it should run on at stock. It's pretty weird.
That certainly does seem weird. But of course -- the hotter the less overclock room. Rusty on my other "wisdoms," I have forgotten the exponential relationships between voltage, heat and speed. I think that heat was supposed to increase proportional to the square of the voltage increase, but only linearly with speed. But then there are factors like electrical resistance or the disproportionate increase in voltage as temperature was higher -- based on resistance.
Even so -- what you're talking about there is a 22nm processor -- isn't that right? Am I right about that for the Ivy Bridge? They've crammed more and more into less space. Given me limited understanding of the actual process of making these CPUs, I could only speculate a great deal of uncertainty or surprises about how these things are developing.
I once knew -- back in the early part of last decade -- An Australian engineer who was working for Intel. He was becoming very frustrated with his work. Couldn't keep up with the new developments. He simply walked away from it. His last remark: "It's getting down to the MO-LE-CULAR level!"
Oh, yeah . . . back to your remarks: Certainly none of those things would ever stress the processor and drive up temperatures like Prime or IBT. But like I said: with mild LLC, the unloaded peak voltage reading on my processor goes up to between 1.36 and 1.37V before the EIST kicks in and it drops to 1.01V. Of course, someone else here spoke to the fact that amperage increases under load. I don't think under this "unloaded peak" I see that the wattage is anywhere near the loaded peak.
Amazing . . . that every so often . . . somebody posts a question like the OP here and it generates a lot of responses. Seems all this had been discussed a year ago. But hopefully, the OP gets a lot out of this . . . and again -- sorry if I might have spawned some confusion per my response to ShintaiDK.
Thermal Throttling has nothing to do with Tcase or BIOS temps. It's all done internal to the processor, and is based on TJunction temps.
The BIOS may also implement "WARNING" and "SHUTDOWN" temps, that may or may not be based on the "BIOS CPU TEMP", which itself may be a calculated value derived from TJunction readings, or they may be from an in-socket thermocouple.
I had concluded -- even though it's just "reasoned" speculation -- that a "TCASE" approximation could be extrapolated. BIOS's I've seen through the Z68 only show one CPU temperature, as opposed to one for each core, and the temps are always considerably lower than those reported for the TJunction sensors.
But Larry -- look what we're saying here -- both of us! " . . May or may not be based. . . ." " . . may be a calculated value . . . .. may be from an in-socket thermocouple" . . . . .. "reasoned speculation . . . . could be extrapolated . . " etc. etc.
The information about some of this topic is sort of a foggy haze, as evidenced from the 2009 forum link I threw up in an earlier post.
I had concluded that the "serious" throttling was, indeed as you say, internal to the processor itself. Somehow I had come away with a notion that the "adaptive thermal monitoring" features in BIOS were some sort of "different" throttling feature.
That being said, it is at least clear -- not differing much from my earlier assumption -- that the "thermal spec" posted on Intel CPU spec sheets per "TCASE" is a "lower bound" of an "overheating condition." In other words, in the more voluminous spec papers they used to publish at the Intel site, there was a chapter on "thermal design" pertaining to features as diverse as fans and case ventilation. So they were saying "We don't recommend that the processor reach a TCASE temperature beyond this value" [my paraphrase or interpretation]. So they (intel) insinuate that the "range of overheating condition" is sort of a bad place to be. Or . . . "not recommended."
Ah . . . from the foggy haze . . . . that's my understanding of it . . . and always seeking "further enlightenment."
FLASH!! New information may be relevant here -- For ShintaiDK, VirtualLarry and others!
Sorry I'm posting another note separately and after my last, but I happened to do a casual web-search.
As I mentioned, there is an "Adaptive Thermal Monitoring" feature of my ASUS P8Z68-V-Pro motherboard. That was the feature which -- when ENABLED -- seemed to show "throttling" for at least one core while running stress tests when the Tj temperatures exceeded ~73C. You all almost had me convinced that I had been . . . . "imagining things" . . .
NOW HEAR THIS! NOW HEAR THIS!!
An over-clocking guide for an ASUS X79 motherboard popped up as a link returned from my Google search string "ASUS Adaptive Thermal Monitoring." Here's the link:
http://benchmarkreviews.com/index.p...sk=view&id=834&Itemid=38&limit=1&limitstart=5
Do a "Find on this page" search for "Adaptive . . . "
Here's an excerpt:
[BEGIN EXCERPT]
Intel Adaptive Thermal Monitor -
The Adaptive Thermal Monitor feature is intended to help protect the processor in the event that an application exceeds the TDP recommendation for a sustained time period. As such during the course of overclocking this can affect the stability of the frequnecy defined. As such it is advised it be disabled when under overclocking and stress testing with high load and high power consumption sythetics or applications. Be advised this will not disable the CPUs internal TCC functionality.
[END EXCERPT]
Note especially the remark about disabling the feature while over-clock stress-testing (which I did). And also -- the next sentence pertaining to "CPU's internal TCC functionality."
I invite you -- any of you -- to comment. ShintaiDK? Larry? Anyone?
I don't think we're finished with this . . . discussion . . . quite yet . . . . Dunno -- YOU . . . tell ME!
Are you serious?
Intel Adaptive Thermal Monitor [Enabled][Enabled] Enables the overheated CPU to throttle its clock speed to cool down.[Disabled] Disables the CPU thermal monitor function.
It means you disable throttle at tjmax.
Just RTFM.
Are you serious?
Just RTFM.
[Per "RTFM"] There, there now . . . I've got several things to do . . . I think I found an Intel White Paper "CPU Monitoring with DTS/PECI." I'll have to take time with it.
Again -- points out what I mentioned -- better -- what a 2009 poster/guru at another forum wrote about a "haze of confusion."
The quote I found came from an ASUS over-clocking guide. They suggest disabling the BIOS feature while OC'ing as it " affects stability of . . . [speed] frequency." It says that the Thermal Control Circuit or TCC continues to function. I might assume that the "over-clocking guide" with its occasional spelling/syntax/usage errors could also be "in error." Or I might assume that they are not talking about a condition where the over-clock setting and stressing with "synthetics or applications" is even reaching TjMax, but that the Enabled setting affects clock cycles and speed when TDP is exceeded (which it is . . . when OC'ing.)
I can accept what the FM(anual) or white paper from Intel says. I can't be sure about the accuracy of the ASUS guide, and frankly -- I may have misunderstood it. But TDP is not TjMax -- it's a wattage that I can see being exceeded when I OC.
It's even more confusing because the "Guide" uses the term "INTEL . . Adaptive Monitoring," and you apparently have quoted something I hope is from an Intel (F) Manual, Spec Statement, or White paper.
But exceeding TDP and TjMax are two different things.
So -- yeah -- I'm serious . . . specifically with regard to the statement "TCC continues to function."
And -- yeah -- I'm not sure. . . . Begging your pardon, but until I do some more reading, I'm not sure of your determination here -- even as I'm sure it is well-intended . . .
I leave adaptive thermal monitor enabled. However my board has something like this. I can adjust my desired TDP limit.
