can you add/remove the same parts
JoeFaheyx
325
hi, i was wondering if you can take a part of a computer out like RAM to inspect, then put it back in while the computer is off. Will you have to run all sorts of things to get the RAM reconized? THANKS
ScrapSilicon
13,625
it will usually survive..pay attention to proper grounding procedures and the dimm slot orientation..
gistech1978
5,047
yes, yes you can.
when the computer is off that is.
you dont have to run anything to recognize the ram.
gsellis
6,061
It will be fine to remove it while it is UNPLUGGED. ;) Newer (last 5 years) computers are always on to some extent while plugged in, so it is important that it is not just off, but unplugged before you start swapping parts.
