I've been trying to overclock my amd 64 3200+ and am having problems. Whenever I try to overclock I run into problems at around 2300+ mhz (stock: 2200 MHz). Basically I start getting Prime95 errors. I have tried everything from changing memory, increasing voltage a bit to the cpu and memory, and even changing the HTT from 4 to 3 or even 2 to see if it would make a difference. It still either freezes, gets errors in Prime 95, or even reboots during start up. I know temperature is not a problem since it is running between 42 - 49 during heavy load, which shouldn't be a problem.
I am beginning to think it's my Power Supply or I just got a cpu that can't overclock well. My +5V is at 4.92 and my +12v is at 11.46, which I believe is low. Any recommendations?
