VirtualLarry
Just ordered one of these bad boys, for $160 + ship + tax.
Netgear, 8x 1Gbe, 2x 10GbE, unmanaged
https://www.amazon.com/NETGEAR-Ethernet-Unmanaged-Multi-Gig-Protection/dp/B076642YPN?th=1
They offer a "managed" version for $250.
Is it possible, if I configure my QNAP NAS units for Teaming / LACP, that the unmanaged switch will automagically configure the two ports that they are plugged into for LACP as well? Is "Passive LACP" a thing? Or do switches NEED to be "managed" to be able to create LACP groups?
I know that with routers, there was "WDS" and "lazy WDS". Lazy WDS was passive, and didn't require configuration on the destination end, to initiate a WDS link. My hope is that LACP, however it actually works, can do the same thing. Or am I just ignorant to the specifics? This is the first time that I've messed with this feature.
PS. THANK YOU, mystery admirer, for the Amazon GC. You know who you are. (But I don't.)
Thank you Wikipedia!
Edit: According to the datasheets, the unmanaged one can't even do passive LACP. Seems unfair to me. Sounds like product segmentation if anything.
https://www.netgear.com/images/datasheet/switches/GS110EMX_GS110MX_DS.pdf
Edit: Now I'm wondering, if I should have bought the TrendNet 24x 1GbE + 4x 10GbE SFP+ web managed switch for $279.
https://www.newegg.com/Product/Product.aspx?Item=9SIA0ZX4FE5652
https://www.cnet.com/products/netgear-gs110mx-switch-10-ports-unmanaged-rack-mountable/
CNet specs state:
(Bolded mine)
According to CNet, it CAN do LAG, but they also mention Port Mirroring, which I didn't think was possible to do passively, I thought that required some sort of mgmt layer to configure that.
So maybe they're mixing the specs up between the two switches, the MX and the EMX (managed).
I guess I'll find out later today.
https://www.smallnetbuilder.com/lanwan/lanwan-howto/30556-how-to-set-up-switch-link-aggregation
I thought LAG/LACP effectively bonded two ethernet ports into one bigger aggregate channel. No?
This link shows an example of link aggregation, using a Netgear switch, that is "unmanaged", but using a separate app on a PC to configure it?
https://www.pcgamer.com/how-to-set-up-nic-teaming-link-aggregation/
Practical notes
https://en.wikipedia.org/wiki/Link_aggregation#cite_note-ieee802.org-4LACP works by sending frames (LACPDUs) down all links that have the protocol enabled. If it finds a device on the other end of the link that also has LACP enabled, it will also independently send frames along the same links enabling the two units to detect multiple links between themselves and then combine them into a single logical link. LACP can be configured in one of two modes: active or passive. In active mode it will always send frames along the configured links. In passive mode, however, it acts as "speak when spoken to", and therefore can be used as a way of controlling accidental loops (as long as the other device is in active mode).[4]
CNet specs state:
Features
128KB packet buffer,
DDos attack prevention,
DiffServ Code Point (DSCP) support,
Energy-Efficient Ethernet (EEE),
IGMP snooping,
Link Aggregation,
Weighted Round Robin (WRR),
cable test,
fanless,
flow control,
full duplex capability,
port mirroring,
security lock slot (cable lock sold separately)
(Bolded mine)
A final interesting aspect about a LAG is it doesn't increase throughput for individual data flows. Each data flow is limited to the bandwidth of a single link in the LAG. In a LAG with two or more 1 Gbps links, the best throughput an individual data flow will see is 1 Gbps. The real value of LAG is in increasing total (or aggregate) throughput between devices. Read this brief presentation for a nice and clear explanation.
