Can this PSU handle these parts?
AgaBoogaBoo
26,108
Can the PSU in this handles these parts?
Intel 865 Motherboard with integrated audio, video, and lan
Celeron Processor - Not sure which one yet
40GB 7200 Maxtor HD
CDRW
Floppy
256MB Corsair
EeyoreX
2,864
I would say yes. mATX PSUs are usually high quality, though low wattage.
\Dan
AgaBoogaBoo
26,108
\Dan
Thats what I was figuring but I needed someone else to say it too because I'm pretty sure Antec would make their cases be able to handle today's components.
AgaBoogaBoo
26,108
Also, this case won't need any extra cooling than it already has will it?
It has one intake from case to psu then I presume an outtake from psu to outside case. It has space for a 40mm fan though...
Remember, everything is integrated so no video card heat, main heat source will be HD and CPU.
newuser
360
I would get at least one extra exhaust fan for that.
That PSU should be fine for your needs.
AgaBoogaBoo
26,108
Why? Nothing in that is really going to be generating heat. I've run a P4 1.7 with a 60GB drive and a Radeon VE with a PSU with only one fan and no case fan. I mean, if there is something generating the heat, sure, I'll get the 40mm fan, but otherwise I need a reason to get it.
GonzoDaGr8
2,183
I would have to say yes on the PSU being ok. Monitor temps in the case for a while before determining if you need another fan or not. Remember, Intel procs have thermal throttling to keep them safe from overheating. Worse that could happen is it slows/shuts down.
AgaBoogaBoo
26,108
Ok, thanks!
