- Mar 31, 2000
- 1,517
- 0
- 0
Or does it have to be repaired by a locksmith? I got semi-stranded the other day because my key wouldn't go into the ignition switch on my truck. I'd never had a problem before and I got lucky that a guy that worked there came out and helped me get it started with a paperclip and the key. He said my ignition switch was dying and I needed it fixed/replaced. Now it's sticking in the start position and sometimes won't go there at all. I really don't want to get stuck again.
Can I replace it myself or do I have to have a locksmith come and fix it? If I can fix it myself, where would I get the part? Ford dealership?
PH
PH
