Can the alternator in a reciprocating engine generator be used in another recip. engine generator?
Howard
i.e. can you swap them? This is assuming that both engines run at an operating speed of 1800RPM.
If so, can you use an alternator from a 3600RPM gasoline generator on an 1800RPM diesel engine, provided that the power ratings are similar?
Should be able to swap them without too much issue if the ratings are similar.
However, rated speed must match. Run a 3600 rpm generator at 1800 rpm and you'll get 30 Hz power and very likely an inadequate voltage - very bad for most things.
Can you? Yes. But you might not get rated output if you're not at the same RPM.
ZV
EDIT: Mark explained it much better.
Originally posted by: Bozono
Ask Minerva.
Well I see someone has given me a namecheck. 🙂
Hmmm the use of generator and alternator in the same sentence disturbs me.
What are you trying to do? You absolutely can NOT swap a genny head out to a driver with differening RPM. If your PTO is half the speed your head must have twice the poles.
Although a AC motor probably wouldn't know the difference, along with a non-computer controled rectifier (ac-dc converters) such as what is in an automotive alternator (usable from 1k to 8k rpm)
Not that any of this really matters, as in practical uses, a 3600 rpm generator on a 1800 rpm motor is pretty much useless if not dangerous.
