Hi ATOT Tech Support!
How are you all doing? About the problem:
My brother's computer has been freezing lately and also restarting itself after being inside Windows for a minute or so. I was poking around BIOS, saw that the CPU was at 100 MHz (normal), and that the DDR was at 100 as well (it's a 2100 stick though). Anyway, I got lucky and it was stable long enough for me to flash the BIOS to a newer version. Now when I was poking around the BIOS, the DRAM speed is at 133 (the CPU is still normal at 100). It hasn't crashed or restarted itself yet. Is it possible that the stability issues actually came from running the ram too slow? It is an el-cheapo stick of Nanya ram (256MB DDR PC2100). Also, is it bad for the CMOS battery if the computer is without power for extended amounts of time?
Thanks-in-advance guys!
off to run memtest on it
