Fractal Design are great cases. I suggest also looking at Phanteks cases.
Not to offend, but why are you looking at CLCs? They really are not as good as top air coolers, are almost all significantly noisier, not to mention half again to over twice as expensive, wear out much sooner and have a significantly higher failure rate. Add to all these negatives the fact that if a CLC fails you have no cooling at all and a major expense replacing it. Only thing that can go wrong with air coolers is the fan(s) .. which don't stop them from cooling and any fan can be used while waiting for replacement to arrive. I think it's obvious I'm not a believer in CLC and never have been. From day one I put them down .. and now many who said I was crazy are now born-again air-heads. 😀
