Im looking at getting a mobile Socket 754, but Ive heard that cooling is a pain. I watercool, and Id like to know more about it before I spend the bucks.
Couldnt find anything on Google. Can anyone point me to an article?
If you're watercooling then there shouldn't be any issues as most waterblocks need to be tightened by bolts, so you should be good to go. If you air cool, the Thermaltake Big Typhoon will also work (I'm using one on a de-lidded X2 3800+).
