- Aug 14, 2002
- 3
- 0
- 0
Hi im new to this forum and my name is rich.
First of all im running an Asus A7V333 w/ +2100 amd xp /w volcano 6cu+.
First my main concern was heat that i was getting around 60C now i dont give a poop because now asus probe shows whenever i try to run pcmark my voltage goes from 13.184 ( what is ALWAYS is it) to 13.284) and that is the limit asus probe has as the threshold and it starts to beep then eventually after about 1 minute of this asus probe beeping the test shutsdown...
The tests taht pcmark did when the voltage went up to max 13.284 was the ZLIB decompressor, CPU test run. CPU 3d vector, memory raw block, and then during HDD it just said "benchmark lost window focus"
Also earlier today after playing warcraft3 for about 1 hour my comp just rebooted... for no reason just boom rebooted??
I am running the bios that came with the motherboard i am to newbie to update myself i dont know how...
Any help would be appreciated thanks.
Ok update i downlaoded latest asus probe and now my voltage is at 12.384... is taht still good/bad?? temp is still 56c while just doing nothing...
I ran both pcmark and 3dmark without a hitch no hat or voltage problem all i needed was latest pc probe from asus. They release buggy software...
