Can someone please help me with math?
Syringer
19,333
The problem is:
If a series circuit has a capacitor of C = 0.8 X 10 ^ -6 farad and an inductor of L = 0.2 henry, find the resistance R so that the circuit is critically damped.
It's a second order linear differential equation!
I truely appreciate any help possible:)
InverseOfNeo
3,719
<< The problem is:
Can't tell you that but I can tell you the resonance frequency. :p
mss242
504
umm, i could probably do the math, but I don't remember the physics. want to state the diffi q?
Syringer
19,333
Nevermind, I just found the equation to use for a critcally damped circuit, you just take 2 times the square root of the L times the 1/C
Thanks for your imput!
