ironxman99
First off, I have a 2002 Nissan Frontier King Cab XE.
About 2 weeks ago I took my truck to the shop to get the transmission fluid drained and replaced. Since that day I've had difficulty shifting into 1st and 2nd gear in the mornings (hard shifting and gear grinding). However, after about 10 minutes of driving it goes away for the rest of the day. I took it back to the shop and they initially checked the transmission fluid level, but I'm guessing that they're still using the wrong type because the problem still exists.
Can anyone help me find out the details on the transmission fluid I'm supposed to use? I checked my manual and it only mentioned ATF (Automatic Transmission Fluid), but its a universal manual so I don't know if that only applies to automatic versions of my car. I called 3 Nissan dealers.. 2 told me to use Gear Oil 80w90, and 1 told me to use Dmatic/Dexron3 (which I think is ATF), so it seems I'm getting conflicting information? I may be wrong. Please help.
Thanks in advance.
Thanks in advance.
