So I ended up stranded in the lake this past weekend with a dead engine that had no spark to the main plug at the distributor. This is a mercury 350. The boat is with a mechanic now, but I an trying to figure out all the possible reasons for this. The simplest explanation would be a faulty ignition kill switch or frayed wire leading to it that is grounding out the spark. If that's not it, a guy here at work thinks it would be the crank position sensor failing to fire. He called it the "stater". Could someone here explain to me how a crank position sensor relates to a distributor on a carburated engine? I figured that once a distributor pin is correctly aligned with the crank, it would eliminate the need for a crank sensor, and the distributor rotor would handle the timing. Having a crank sensor makes perfect sense to me for a fuel injected engine, which this is not. The guy was a mechanic for 8 years, so I have little reason to doubt him.
Could someone please school me? TIA.
