JPB
Ok, I am making a custom case. And running into a few problems along the way. Now...I usually use 80mm fans. The fans I have here are supposed to be 80mm...but they are measuring differently. As if it is a 96mm. Now, can someone tell me how big to cut the hole for a 80mm ? And a hole for a 120mm ? Or can someone direct me to a site that has actual fan size or something of the sort ? Also, when measuring a fan, do you measure the inside of the casing ? The outside ? Or the blade itself ? Thank in advance
Edit : The fans ill be using is 3 5/8 on outside casing.
Inside the casing is 3 1/2
The holes are 3 2/8 from the left to right
John
John
