Which "new" 8800 cards? The GT 512MB is already kinda-sorta in stores now. The 256MB version, IDK. The "new" version of the GTS might be in December.
Yes, you'll see a decent improvement by overclocking the processor. Overclocking memory will NOT give you the same yields in performance as will the processor.
Originally posted by: Arkitech
what's the cheapest possible choices
The 8800 series fans/heatsinks are usually enough.
There isn't much of a performance bump after 2GB RAM. Either get 2GB or get 4GB. Go for some cheap DDR2-800 for best bang/buck. For 4GB, eWiz has Super Talent single 2GB sticks for $51.50 each. Just buy two. For 2GB, look for a rebate deal (if you deal with those). Otherwise look for deals around $50-55 for a 2x1GB kit.
For a decent and really budget PSU, look for rebate deals on the Antec EarthWatts series. Recently the 500W version was at Outpost.com for $30 after rebate, with free shipping. If you don't want rebates or want more power, then you can get this beefy
600W BFG power supply for $50 plus shipping. It is listed as "scratch n' dent" but mine were pretty much new, just w/o retail packaging. These put out 39A combined on +12v. Only two drawbacks are IIRC they aren't as efficient as newer units, plus the 80mm ball bearing fans are kind of noisy compared to "quiet" PSUs. For a much cheaper alternative, eWiz has the
Sparkle ATX-400PN power supply at $30 (about $15 less than Newegg), making it a really budget way to get 29A on a combined +12v.
If you're going to overclock (even a bit) then why don't you look at cheap Intel chips? At the price of an AMD 6000+, you have a few Core 2 Duos to choose from. If you're going REALLY cheap, then go AMD - but lower end than that 6000+. For instance you can get an x2 5200+ (look for lower wattage 65W version) for around $120-125 and overclock it to faster than the 6000+. Motherboard-wise go for a cheap Biostar Tforce 5xx series at around $60-70. If you're willing to pay more for the CPU/motherboard and will overclock, go Intel. The Abit IP-35E is a decent board for around $100 before rebates (when available, often $20 MIR). Go for the cheapest E4x00 series. Next real step up is the E6750 at $195. If you're tight on funds, go with the E4x00 series and put the extra money into the video card. For CPU fan/heatsink, if a tiny overclock then stock is fine. Otherwise look for heatpipes. For rebate deals the Cooler Master HyperTX2 is a good one that is often available for around... FREE after rebate. The HyperTX and HyperTX2 look around the same, but the "2" version works with both AMD and Intel while the original you have to buy for one or the other. Beyond that, any big/heatpipe unit should be reasonably decent. For top notch cooling, look for the "tower" heatpipe style with 120mm fan.
anyone?
Have patience! Not everyone "lives" on the forums.
