Can someone bring me up to speed on the best case fans?
Ken90630
1,571
Hey, All,
I haven't kept up with case fans for the last several years, and I was wondering if you guys could bring me up to date on which 80mm case fans are considered the best nowadays (if there is any consensus). I'm looking for reliability and decent airflow without a lot of noise. I don't need to create a typhoon, but the fans don't need to be completely inaudible either. Just quiet, with decent airflow. I don't need UV reflectivity or rpm monitoring. As for reliability, I prefer fans that last at least five years before they fail or start chattering.
When I had my head in the game from about 2004-2010, I liked the Panaflo L1A (Hydro-Wave bearings) and Cooler Master sleeve-bearing fans. Then I remember the Panaflos started getting produced in China rather than Japan, and there was some debate over whether or not the mfg. quality decreased.
I see that the Chinese Panaflos (with the BX suffix) are still available at SVC. And I see fans made by Gelid getting high ratings on Newegg. Gelid wasn't around several years ago, so I don't know anything about them. I formed a negative opinion about SilenX back then, so I'll avoid them.
Any suggestions would be appreciated. Basically, I'm looking for the closest thing to the old Japanese-made Panaflo L1As, I guess.
Subyman
Moderator <br> VC&G Forum
Mar 18, 2005
7,876
32
86
Gentle Typhoons continue to be the best all rounder. SP120's are great if you require aesthetics with your performance. The best value fans have always been Yate Loon low/medium/highs depending on your need. They are only ~3.99-4.99USD each. I've used Yate Loons countless times with great results. If it is a functional build, its hard to pay 2x more for anything else.
Edit: Oops I just noticed you need 80mm. I don't think much has changed in that size since you stopped following them years ago.
