CAN SOMEBODY PLEASE HELP ME OUT
JohnyB
I have a Microstar K7T Turbo with an Antec SOHO Server case. This Antec case has an Antec 300 watt power supply. I have problems starting up my computer. When I first start it my display doesn't turn on. I have to press the restart button. Does anyone here have any idea whats wrong? :frown:
silhoutte
Banned
Mar 1, 2001
316
so does it boot up correctly after you hit the reset button?
more detail about your problem and what you've done will help.
JohnyB
It boots up perfectly fine after I press the reset button once or twice. It runs perfectly stable. I have my processor 850 Thunderbird overclocked to 1000. However, even at default 850, I have the same problem.
JohnyB
I found my problem. Under DRAM Timing by SPD, I selected No, and chose my own settings. It starts up fine now :)
