Can somebody help with me two probability problems?
ctark
726
First one is.
A cellular phone manufacturer randomly selects 8 of every 100 phones from the assembly line and tests them. If at least 7 out of the 8 selected pass inspection then the batch of 100 is considered acceptable. Find the probability tht the batch is considered acceptable if there are 4 defective phones in a batch.
I set the problem up as
(96 C 8 + (96 C 7 x 4 C 1))/100 C 8
But it came out with a approx 1.009, which is wrong because it needs to be below 1.
Second one:
A fair six sided die is rolled 10 times. What is the probability that the roll of 2 will occur exactly 6 times?
I have yet to find an example to give me clues how to do this.
ctark
726
I figured with all the smart people here with 7 figure incomes somebody would know how to do this.
rivan
9,677
It's not 11 am (cst) yet. Most of them are sleeping in, comfortable on their money-stuffed mattresses, next to their supermodel wives.
BigJ
21,330
On the second one, you need to compute the odds of it rolling 2 (1/6) 6 times , and rolling it not 2 (5/6) the other 4 times. It seems fairly intuitive, but the 2nd part is where most people slip up.
aesthetics
1,355
GTFO.
Maybe we just don't want to help some punk who posts his homework on the internet.......
UncleWai
5,701
68
Hi I will do those questions for you if you agree to let me do your girlfriend too.
It seems you haven't even tried to put common sense into the probability concept and just tried to plug some numbers into formulas that don't apply.
First question, what are the scenarios that the test will pass?
7 of 8 tested functional, 8 of 8 tested functional. Probability of picking 1 from the batch to be functional = 96/100. probability of defective is 1 - P(functional) = 4/100
Second question, apply the same complimentary probability. Each roll of the dice is independent.
ctark
726
On the cell phone problem I did it the same way shown above on my homework and it was counted correct, but he could just have overlooked it. I redid the problem in my calculator and i got a .96xxxx of probability acceptable. I believe thats right.
puffff
2,374
The first one basically boils down to a much simpler problem. Given 8 phones, and knowing that each one has a 1/25 chance of being defective, what are the chances that none of them are defective?
(24/25) ^ 8 ought to be your answer.
BigJ
21,330
Your restrictions are too severe.
1 of the 8 is allowed to be defective for the batch to pass.
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
Don't forget that there's more than one order to have it happen.
potoba
738
Will give you the answers when i have time.
jonks
13,918
20
the smart people like me picked careers where we don't have to do math problems. but the answers are
1) mary poppins
2) pickles
Epic Fail
6,252
Yup, no 2 isn't as easy as it seems.
OP, read this.
http://en.wikipedia.org/wiki/H...geometric_distribution
GagHalfrunt
25,284
1,997
People with 7 figure incomes didn't get there by doing someone elses homework for them.
